I've ordered throw internet a 2 GB card 4 my N73.do u think it will work on the N73?the card include's an adaptor
Card Question
Yup, as long as yr firmware is pretty new it shud
i have this firmware V 3.0705.1.0.31 .i think its the latest right?it will work on this firmware?
i have that firmware it will work?
MaSteR_KeN wrote:i have that firmware it will work?
I have the same firmware, and I have Transcend 2GB 80X mini SD card. It works
flawless.
With this firmware, phone should support 2GB mini SD card. But again check the
compatibility list of the mini SD card you ordered.
I should think it should be alright. 😊
Atomic_Guy wrote:I have the same firmware, and I have Transcend 2GB 80X mini SD card. It works
flawless.
compatibility list of the mini SD card you ordered.I should think it should be alright. 😊
the card has the same dimensions like the one i have in the phone right now and it says its compatible the cellphones.
