After about a months use the phone has become slower, especially sending texts and responding to certain applications. Memory looks like this:
on board
in use 24mb
free 22mb
calender 10kb
contacts 35kb
messages 36kb
images 5778kb
apps 135kb
memory card
592mb in use
395mb free
33kb images
355mb sound files
Now I do have a couple if videos but these don't seem to be recognised.
This data was taken via file manager.
Any ideas to speed it up again?
Can I do a reset that won't change any of my settings or loose data/apps?
thanks
Paul
Mine started slowing down after I installed Gizmo VOIP. it is horribly slow now.
Install the "SMS Accellerator" fix (released last September):
http://www.nokia.com/A4149142
Or update to the latest phone software (firmware) where the fix is supposedly included:
http://www.nokia.com/softwareupdate
Hi there -
i've got the latest firmware and this upgrade doesn't fix the speed problem - i found when I installed gizmo the phone slows down dramatically and the battery lasts a shorter period of time.
I'm going to do a hard format/rest and try using it for a while without installing the gizmo VOIP app to see if it makes a difference.
