N80 internet editor web browse can't display unicode ???
4 replies · 4,683 views · Started 04 March 2007
When I go to Vietnamese website, the font does not have glyphs (characters) corresponding to a particular Unicode code point, a blank white rectangle is shown. And I want to see the web site with Vietnamese language.
And when go to web site have forum, I can enter my username and password but when I login the web site refuse me. It redirect me to a login page or show the message that i haven't login yet. Maybe I think that my phone N80ie cookie dosen't work. is that right ? Certainly, I set my phone cookie is ON.
My phone was bought in Singapore so I not sure it have Vietnamese support. How can I install Vietnamese language into my phone ?
Thank you for your reply !
I use N80 I bought in US, and it can display Japanese fonts after replacing original font. Does your N80 originally come with Vietnamese fonts?
It may enable you to read Vietnamese pages by the same way I use if your N80 does not contain Vietnamese fonts.
First, you have to find the name of the original fonts your N80 uses, at the same time find the alternative Vietnamese fonts you need, then rename the fonts as N80 fonts. Afterwards, put that in your miniSD card Z drive (I forgot exactly which folder, but if you need to do this, I can find it for you). Then just restart your N80.
HTH
Thank you so much for your reply.
Please kindly help me to find some Vietnamese font and show me how to replace the original font.
Because I don't know much about my phone N80 internet editon.
I don't know anything about Vietnamese fonts, and I am not sure what I did could apply to other languages, but I can explain how I did it.
1. Check the firmware. I heard N80 has to be at least Internet Edition v4.0632.0.38 in order to use fonts located in the SD card.
2. Install Y-Browser.
3. Check Z:\Resource\Fonts (handset) to see what kind of fonts in there.
My N80 has the following four fonts:
S60SNR.ttf
S60SSB.ttf
S60TSB.ttf
S60ZDIGI.ttf
4. Find the alternative fonts (one set of fonts is enough), then save it in PC as,
S60SNR.ttf
S60SSB.ttf
S60TSB.ttf
5. Put the newly named three sets of fonts in E:\Resource\Fonts (SD card).
6. Restart the phone.
Hope this helps.
PS. At my previous post, I describe the drive Z as SD card drive, whichc is wrong.
OK, I will try by your prompt. But I think it will help my phone apply new font only.
All I want is when I connect to internet via wifi of my phone, the browser is display the correct Vietnamese font of the page to go to.
And now, I buy the new miniSD card, I not sure it have the font folder, but I will try to find it.
