[FONT="Verdana"]I have installed a new font on my Nokia 6630 and my default font have been deleted and none of the restore nor using the nokia software updater didn't work.I have used many tricks for changing the font and have tried many of them but none of them were the original one.Is there anyone who can give me a link of nokia 6630 default font rather in .sis or .gdr format?
thanks [/FONT]
I Need Help With My Nokia 6630 Font?
The original font is not deleted, as it is placed in ROM. What you need to do:
1. Grab FExplorer from www.gosymbian.com in case you don't have it already
2. Go to C: or E:\System\Fonts and rename this directory from "Fonts" to "ABC" for example
3. Reboot your phone
4. Delete the "ABC" folder
It will work 100%.
Thank you very much for your advice,you really saved me.I appreciate that 😊
You're welcome. In the future note that the fonts can be deleted only in this way because they are used by system. Any file in use cannot be deleted.
you can install on your symbian phone any font you want, also as wasy as you install it you can remove it, very simple, you have to install on your phone FONT REMOVER! if you do not want anymore a specific font just open the app. font remover and it will automaticaly remove the unwanted font, after that restart the phone...
hi
would u plz tell me how to post a message in the groups.
reply
