Dear All,
I wanna know in which folder the applications are stored in N70?
Best regards,
Creator.
Dear All,
Best regards,
Creator.
It depends on the application. Some are on the SD card. Some on the phone memory.
Variations occur on the SD card. Could be in E:\Others, could be in E:\system\Apps. These are only two of the possibilities. The data for the programmes could be stored almost anywhere.
Perhaps if you have a particular programme in mind then somebody could tell you more.
Basically they are stored in \System\Apps\ and the uninstall info in \System\Install\
Anyway, a sis file contains some other files too, so is pretty hard to "uninstal" manualy, because you don't know which files can be deleted.
