Memory card slot opens
3 replies · 2,251 views · Started 05 March 2007
Hi there,
Does anybody have a solution 4 my problem?
My sd card pops out of the memory slot (doesn't close that great)!
Is it possible 2 male the card stick in the slot? Maybe with a small point and push it until it clicks? I can't make it 2 work...
Any1?
On wich phone? N73? Is almost impossible, becauseis so hard to open... If is the case, you have a hardware problem, then go to a Nokia Service, is the best thing to do.
I have a N73....
I don't think it's a hardware problem.
I think the slot comes open because the sd card won't click in to a slot (like the N70 or 6680)
Thanx anyway 4 ur reply
If it doens�t click, reinforce the idea of hardware failure. Try the repair service - free on guarantee.
