i had downloaded "bricks" & when i tried to open it, it said "system opx..not installed" or something to that, so i removed the opl & all the opx games, now when i try to install it it shows me an error & says "THE PROCESS CANNOT ACCESS THE FILE BECAUSE ANOTHER PROCESS HAS BLOCKED A PORTION OF THE FILE"...what do i do?
please help.
thanks
gaurav
If you are trying to install OPL again, bear in mind that there's one file that is a bitch to remove so that may be stopping you install again by not letting you overwrite it.
you said "there's one file that is a bitch to remove" which file is that & how do i do that? please let me know, so that even i can enjoy the likes of Bricks etc.
thanks
gaurav
Here is the answer courtsy of RMR (http//www.rmrsoft.com)
When removing OPL.sis the font file used by OPL (\System\Fonts\Eon14.gdr) may cause the removal to fail since it is in use. If you have installed OPL.sis on the MMC card (D\ drive) it is recommended that you remove the MMC from your Nokia 9210 Communicator and then reboot the device WITHOUT the MMC in it. When fully booted, re-insert the MMC and use File Manager to delete D\System\Fonts\Eon14.gdr.
well thanks for that, it worked & now at last ive got all the games i wanted too.
Yahoo!!!
thanks a ton again.
gaurav
