Hi all... Am a new commer 4ur site... I have Found Many interesting things going on around!! But i Needed One help ... I just want to know how can i Put a image as my screensave(Power Saver)r>> I use Nokia N80 .. When ever my phone is adle it shows up with a date n time white background screen... Am tired of watching it!! can any one help me out?? Thankz in advance...
Screen saver help for N80
movies wrote:Hi all... Am a new commer 4ur site... I have Found Many interesting things going on around!! But i Needed One help ... I just want to know how can i Put a image as my screensaver>> I use Nokia N80 .. When ever my phone is adle it shows up with a date n time white background screen... Am tired of watching it!! can any one help me out?? Thankz in advance...
the date and time showing is a power saver, not a screen saver. If you started to scroll pictures or movies as a screen saver I think your battery wouldnt last longer than a few hours.
You can change the time/date to text if you want... but its nothing special.. just go to THEMESE and choose your theme and edit it.
kontraband wrote:the date and time showing is a power saver, not a screen saver. If you started to scroll pictures or movies as a screen saver I think your battery wouldnt last longer than a few hours.You can change the time/date to text if you want... but its nothing special.. just go to THEMESE and choose your theme and edit it.
Hi bro... That was really good info da!!
But can u suggest me a soft which puts images as my powersaver??
you could try summat like this:
http://www.series60v3.com/index.php?categoryid=8&p13_sectionid=2&p13_fileid=335
movies wrote:Hi bro... That was really good info da!!
would be a huge mistake ....you will find your battery power consumption going up real quick...you have an extremely high definition screen on the N80 and the power save mode is there for a reason because the screen drains the battery very quickly.
I think this is the reason they have gone for a lower resolution screen on the N95.
I found out when I used a full screen analogue clock face as my screen saver, and the battery lasted about 4 hours Haha...
But have a look at this ..it may amuse you until your battery dies 😊..
http://www.series60v3.com/index.php?categoryid=8&p13_sectionid=2&p13_fileid=1037
hahahah that must SERIOUSLY drain your battery!😮
