Just goT N80 & I like it, just a few questions though
3 replies · 1,669 views · Started 06 March 2007
Just got my Nokia N80 and I really like it, just a few questions
1) On my N70 if i used more than one text message (ie over 160 char) it would prompt me before sending to say message would be sent in 2 parts etc. Thus allowing me to edit message to make it smaller if need be to save on cost. Does this option appear on the N80 :con?
2) Having read in forum about fault with text messages displaying SURNAME, FIRST NAME, is there a work around for this yet?
3) HANDY WEATHER will not allow update via WLAN is there a work around or another application that will allow this
FA
When writing a text on the N80, in the upper right corner there is a character count saying how many characters more you can put in that many texts, and the number of texts it counts as so far in brackets.
i.e. - if you are texting and have "12 (1)" in the upper right corner, it will only count as 1 text message as long as you dont put more than 12 more characters in.
LOL@Bigzy.... come on mate... get to the point! :tongue:
Re the SMS firstname, lastname problem the only work around for that is to edit the name so it all appears in the firstname field... so instead of
First name: John
Second name: Smith
it would be
First name: John Smith
Second name: (empty)
