I wanted to know if there was a way that I can use voice over IP using a dial up connection.
voip calls using dial up
you should try to download gtalk or skype. but i dont think skype will work that good on dial-up.
jemimarosa wrote:I wanted to know if there was a way that I can use voice over IP using a dial up connection.
i stumbled upon voip.com while i was surfing the net. i have read there that it works on dial up. i guess its the only voip that works on dial up. skype and gtalk require hi speed internet. i think you should give voip.com a try. :icon14:
how can you call using voip.com? will it require me to sign up? is it like skype?
naah. just go to the site and click the "make a call" button. after clicking that, you'll come to this page which requires your phone number and the number that you'll be calling. just fill it out and call. that easy. :icon14:
thanks a lot man! i have to tell everyone about voip.com!
hey guys, ive read all your posts and it seems like it can help me save more money too! i think i'll try that voip.com of yours.. thanks a lot.
always glad to help! if you're on dial up, i think voip.com would also work on it. check out voip.com for more info.
