I bought a Nokia Music headset HS-20, AD-41 from a ebay seller.
I tried it on my n73 standart edition.
But the buttons do not work at all.
So i send it back to the seller.
Received a other one but same problem.
I can hear music from the headset but buttons do not work.
As i saw on nokia website the headset is compatible with my n73.
This headset is the standart headset for the music edition.
So i just don't understand why it does not work.
Anyone in here who can give me some advise?
Or anyone who has the same problem?
ebijma wrote:I bought a Nokia Music headset HS-20, AD-41 from a ebay seller.
I can hear music from the headset but buttons do not work.As i saw on nokia website the headset is compatible with my n73.
does you phone show that you music headset is connected, i should have a little icon at the top of not , you haven't connected it right.
> N73Me_2007 : does you phone show that you music headset is connected, i should have a little icon at the top of not , you haven't connected it right.
Yes its shows the icon.
> naughtydude : restart ur phone
I tried but no luck.
Thanks for your answer to my question.
I have tried many things but it still does not work.
Maybe the n73 standart edition doesn't support this kind of headset.
But nokia website says it does.
I have the AD-41 and it works fine on my ME. There is no reason for it not to work on non ME versions. It also works fine on my 6230i and 6680.
Yes , i got it working.
Thing is i first have to connect the AD-41, then after the n73 detected it i can connect the headset.
Then everything works fine.
Thanks for all your help.
