is S60 really ready for seamless VoIP and data sync with open WiFi spots?
19 replies · 7,082 views · Started 10 March 2007
Hi
thank to FON activity the open WiFi spots are now everywhere, and
it forced me to buy E61, which seem to run under S60. But i don't realize any of my topmost goals are met. So, your comments and hints are very wanted and welcome.
My topmost goals -- which are all failed as for now at least -- for the purchase were:
0. Seamless VoIP with any open WiFi spot.
That is, if i dial near free WiFi then i expect my E61 software to detect automatically the presence of it and be able to make not a cell-network connection, but the VoIP one.
tried "FON WiFi" from Spotigo GmbH for detecting FON WiFi spots it doesn't seem to work good with standard la Fonera.
"fring" also doesn't work via la Fonera from FON.
1. Seamless and secure integration with Google Mail
i tried "Mobile Google Mail". it works, but it doesn't notify me about new
email on welcome screen or with LED 😞
maybe i just need to setup some built-in S60 features?
2. Seamless and secure integration with Google Calendar
probably i could get it with goosync, but they have then access to my
google calendar... no way without it?
3. Seamless and secure instant messenger service (preferably Google Talk or ICQ)
tried MGTalk and GoTalkMobile. they doesn't work with open FON
WiFi spots, or it is rather my own inability?
The Nokia device itself seem to be more then good enough for these goals. The question is about software running on top of it.
Many thanks in advance for advices!
Sincerely,
Valery.
vak wrote:Hi
Dear Valery,
I think the phone is really ready for VoIP on a bussiness environment. You see, it's a shame that a single thing prevents the use of the phone for a broader audience: auto-connect to open hotspots. You have to create a profile for every hotspot you want to use, OR connect to one via ParkWiFi (you have this program, right?) and use the internet telephony program to connect through it. It's not automatic, and it's a pitty it is the way.
Other than this, if you use it on a fixed hotspot, that is, the one at your house, or the one at your work, it works great, and the voice quality is amazing - way better than any softphone.
vak wrote:1. Seamless and secure integration with Google Mail
True - but that you can do! (I'd prefer the LED to work for SMS, however). This is how you can do:
1 - Set your E61 to retrieve your e-mail periodically.
2 - Set your Standby to show your Gmail folder on the "desktop"
Voil�! Whenever you get a new e-mail, it will turn on the LED AND will show it on the desktop!
vak wrote:2. Seamless and secure integration with Google Calendar
This is a tough one, as I don't use Google Calendar - I use Apple's iCal instead, and it works beautifully with it!
vak wrote:3. Seamless and secure instant messenger service (preferably Google Talk or ICQ)
Fring does it for me for basic IM, but Agilent Messenger works fine as well, including file transfers! Have you checked it?
Actually, I believe E61 has a lot to evolve, but it's one of the best ideas of a smartphone I've ever seen - it works great, and it could work even better if Nokia had a better idea of what users would like to do with it.
Cheers,
Francis
Dear Francis, many thanks for your detailed answers, today i will go them through and will be back with my comments.
oculos wrote:... OR connect to one via ParkWiFi (you have this program, right?)
there is no bundle for E61. there are bundles for N80, N91 and two bundles for Nokia 770. but google says ppl seem to use wifiparker with E61. the question is which bundle? 😉
vak wrote:there is no bundle for E61. there are bundles for N80, N91 and two bundles for Nokia 770. but google says ppl seem to use wifiparker with E61. the question is which bundle? 😉
Er... Have you tried to install it from the Catalog application? I think that was how I installed mine, but it was sometime ago...
oculos wrote:Er... Have you tried to install it from the Catalog application? I think that was how I installed mine, but it was sometime ago...
Get the one for N80 or N91, it will work - i believe that's how i installed mine.
a short update: just tried my public SSID from "la Fonera" router through WLAN-USB from my PC. web surfing, google chat and skyping seem to work good. that is, the connection troubles i have are really associated with my E61 and/or how i use it.
The Internet Telephony application with version 3.x of the E61 firmware saves you from needing ParkWiFi or creating a profile per HotSpot.
However, I think the public HotSpots preclude such an activity. They all have some basic web page you have to get through before they let your device route traffic. However, if you were to open Web, try to go to Google (or anything per se), Search for WLAN, choose the open hotspot, get past the login or hello page, and THEN launch Internet Telephony, you should be OK.
I haven't been able to find any SECURE IM products, which saddens me. I THINK Agile routes you through its own servers as proxy, which is even LESS secure.
oculos, ParkWifi for N91 seem to be with much bigger screen 😉
jaydisc wrote:The Internet Telephony application with version 3.x of the E61 firmware saves you from needing ParkWiFi or creating a profile per HotSpot.
jaydisc, i went my E61 hundred times through but saw no "Internet Telephony application". where it is and how could i check its version?
i start to believe that there are some different editions/branding, where even the very basic features work different. for example sometimes i see idiom "E61 Internet edition". hm, not sure if my is an "internet edition" one.
another point: my E61 is not simlocled or netlocked but was branded from T-Mobile. maybe some artifacts are expected just because of this?..
BTW, on Nokia's E61 software page (europe.nokia.com/A4162071) we see two (quite expensive) connectivity suites. i hope it is not a sign that build in connectivity is not OK...
UPD:
N91 doesn't seem to have a larger screen:
Display size
Nokia E61: 320x240 pixels
Nokia N80 Internet Edition: 352x416 pixels
Nokia N91: 176x208 pixels
but the park cast screen layout is messed up :-/
Well, not really, at least not if you want it to connect automatically to an open hotspot...
Microsoft has its own MSN for Symbian - I'd assume it connects directly.
vak wrote:oculos, ParkWifi for N91 seem to be with much bigger screen 😉
Not really, as you said... 😉
It's under "Installations" - here it's the first app there...
I don't think so, but who knows? You could always hack it and get it using a default firmware, but that's kinda risky.
Er... I never used Nokia's connectivity stuff (I use a Mac), but I never needed them anyway...
then in my case it is definitely not here. yet. trying to find it, but it doesn't look easy. if it is a part of firmware then -- too bad for me...
I've shuffled my apps all around and can't remember where they originated, but here's a screenshot of the icon (note that its name is abbreviated to "Internet Tel." and it's interface.
User posted imageUser posted image
Val, why don't you do a firmware version check for us. On the standby screen, enter *#0000# and let us know the result.
Regarding ParkWiFi, I was unaware of its ability to auto-connect you to Hotspots, but regardlessly whether it can or cannot, it's not going to register you with your VoIP provider. Internet Telephony is still quite necessary for that. And since Internet Telephony can connect you to the hotspot, Park WiFI still seems to me to be a wasted app. Please correct me if I'm wrong as I'd love to streamline that process as well.
Oh, no - I meant by suggesting ParkWiFi in order to find hotspots, not meaning that Internet Tel. would automatically use it to connect to an available hotspot. But it seems to me that ParkWiFi is necessary to connect to an access point whose profile you don't have on your phone - or can Internet Tel. do that by itself, even if not automatically?
The biggest prob with Internet Tel. is that the damn thing should connect to whichever access point the phone itself is connected! Other than that, you have to create a profile for each access point OR make it connect manually to an ap you're connected to.
Cheers!
oculos wrote:or can Internet Tel. do that by itself, even if not automatically?
Yes!
oculos wrote:The biggest prob with Internet Tel. is that the damn thing should connect to whichever access point the phone itself is connected! Other than that, you have to create a profile for each access point OR make it connect manually to an ap you're connected to.
That's not a bad idea, but this still requires you to have used something else to connect.
Again though, I think auto-connecting to open hotspots is not a reality, as when you think of T-Mobile or Panera bread, and so many others, even if you were to auto-connect to the hotspot, you ain't routin' VoIP traffic until you've manually browsed a couple of web pages. So, if Internet Telephony (could be) set to auto-connect to all these open hotspots, I'd expect a failure rate of about 80% without manual intervention anyway. Even if you look at Linksys's high end WiFi VoIP phone, they had to put a web browser in it for this exact purpose.
Can anyone tell me a large brand of open WiFi hotpots that will instantly route traffic upon connection? Meaning no login, no pay, no nothing? T-Mo and Panera will fail.
jaydisc wrote:Val, why don't you do a firmware version check for us. On the standby screen, enter *#0000# and let us know the result.
hey, jay, thx for your hint! now i know to check it 😊
3.0633.09.04
20-11-06
RM-89
Nokia E61
ha! i thought this is kind of online shop selling software for the nokia (currently i am not in position to buy anything)
Just use the builtin email app, it works and (of course) it's integrated with the standby screen.
