My Dear 7650 is Dead!! please help me!
18 replies · 4,539 views · Started 01 January 2003
hey,
a few days ago i tried to install videommswind. this app was installed sevreal times on my device. after this installation i got an error. i tried to open the program but my device stuck, with no other option i took out the battery.
after re-inserting the battery i tried to turn on the phone. the nokia logo goes up and then fade out... i don't know what to do!
I tried all the known tricks:
1. putting the phone for a long time without a battery
2. Charging the phone for a long time.
My Nokia Service center does not suppot BT devices. I have no place
to fix it. Does anyone know how to flash the phone by your own?
:bad-words:
please help me!
Gideon
It really sucks when this sort of thing happens - I'm sorry to hear of your predicament!
What do you mean that your Nokia centre doesn't support BT devices? They should have a facility, or at the very least contact with a facility that will be able to fix your Nokia phone.
well,
The army in my country use the bluetooth for their on stuff,
the minister of comm' is afraid that people will listen to army radio.
No bluetooth allowed here.
Gideon
Get a flash box for 500$
or a bit cheaper, ask your NSC to send the phone to some other
NSC for repairs.
😃 I forgot the most obvious solution, thanks IZZO 😃
so search 7650 FAQ for hard reset, when it gets online.
http://www.allaboutsymbian.com/support/directory/viewcat.php
Make sure you have full battery power, and have the battery cable plugged in for extra security 😃
I cant hard reset, my phone does not even go to this stage.
i cant write anything!
my firmwire is 3.12
Gideon
I think that you dont have to see anything written on screen for it to work.
If you can get your phone to start for a bit, and type it blind.
Try this to get to phone mode.
With your phone off, turn it on, while its booting up, press the Menu Key and don't release it.
OR,
This procedure will skip the startup procedure of your phone.
power off your phone, press Abc button and power on phone (keep
holding Abc for approx. 30 seconds).
[quote="kobe24"]Try this to get to phone mode.
OR,
holding Abc for approx. 30 seconds).[/quote]
THANK YOU!, I did not tried it yet cause i dont have the code, (anybody??). Is there a chance that it will kill my phone?
Thanks All,
Gideon 😃
Thx,
R u sure that i don't need the phone booted up?
the only thing i see is the Nokia logo (and even this for a few secs)
Gideon
I have not had expirienced this problem but many of AAS users did.It was solved by doing a hard reset.
It will not hurt to try it,well it might,your data will be lost.
be carfull if you try a hard reset with a not fully charged battery and without the phone being on the charger you WILL have t send the phone to nokia.
Well, I dont know if my phone even charge. i will charge a battery with another 7650.
Hold your fingers for me...
Gideon
It did not work!
i tried to ABC trick and the phone did not even respond, i also tried writing the Hard rest code blindly...
No luck for me.
any tips guys?
Gideon
