indian radio on N80????
3 replies · 2,879 views · Started 11 March 2007
hey can some one plz help me i want to get indian radio on my N80IE like the BBC radio but i want indian radio does anyone know what will work??? and can i get indian chanels on my n80 like live stream?
I use the program that EricSeale posted above, works great, Open Source is just the player, you will still have to do some work to find the Radio stations, and make playlists for the program to work. They program comes with a sample playlist. Download both The Internet Radio client and the Shoutcast engine and install on ur N80.
Go to http://www.shoutcast.com
In the search type in Hindi or Indian or whatever genre u like:
It will list all the channels available then right click on the "TUNE IN" button and save Target as, name it and save it as a .pls
For the complete instructions go here:
http://samgonzales.blogspot.com/2006/10/more-radio-stations-for-nokia-e61.html
For sample Playlists:
http://base.google.com/base/a/1478951/D14911695749818596598
I suggest you download winamp and listen to the stations on ur computer 1st and then decide which ones u like best, put all your favorites into one playlist using the intructions from the links above and then put that playlist On ur N80 mmc. I listen to Internet radio on my N80 all the time.
Also you can use these playlists with ORB put them in your Fav's in the Internet Radio, and it will use realplayer to play them.
