sat nav for my n73
24 replies · 7,973 views · Started 11 March 2007
i am looking for some sat nav software to put on my n73 i have got tom tom 6 at the mo but it has the map lagging thing
so wot have you run on your n73 that works with no map lagging
thanks spurry05
thanks i will have a look
and you must be the only one who has no map lagging on your n73
may be you can tell us all how??
spurry05 wrote:thanks i will have a look
I have no lags. I cant really say whats caused the lag on our phone apart from
not having up to date firmware. May be update firmware and have the latest
tomtom software...well I have version 6.1 and it works fine.
i have
firmware v 3.704.1.0.1 this is the newist out
tomtom 6 is 6.010 build 7640 gps driver v1.20
gb map v650.1046
western europe map v660.1219
it dose run better with the we map...
I also have map lag on my n73
i have
firmware v 3.0638.0.0.1 this is the newest out for 3 nework
tomtom 6.010 build 7640
gps driver v1.20
gb plus major roads of WE v650.1046
Can those who dont have map lag please post their firmware and tomtom versions and also their network so us who have got lag can try to match up our phones with theirs.
this would be great help and thanks in advance 😊 :icon14:
hi and thanks would this be any good ***.misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=259717&sku=128648
spurry05 wrote:hi and thanks would this be any good ***.misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=259717&sku=128648
Strangely I have exactly the same card but mine is 2GB. How often do you have the lag during your whole journey?
ok , i posted before about lag on my n73 with tomtom6, i have been onto my memory card manufacturers (dane elec) , they say that if the card has been formatted in fat 32 (win xp default) this can slow down the speed of the card , its supposed to be a x66 card and it is supposed to be formatted using fat 16.
i dont know if this will help , i am going to try it later on and give it a road test tomorrow.
I get my lag when the voice prompts come on and the map stalls for about 2 seconds or so , those people who dont get any lag could you please let me know if your memory card is fat 16 of fat 32 , thanks...
my pc tells me my sd card is just fat and not fat32 i can format it to fat or fat32
so i think when i got it and did a format in the phone it will have done it to fat...
mmorpheus1 wrote:ok , i posted before about lag on my n73 with tomtom6, i have been onto my memory card manufacturers (dane elec) , they say that if the card has been formatted in fat 32 (win xp default) this can slow down the speed of the card , its supposed to be a x66 card and it is supposed to be formatted using fat 16.
Just re-formatted mine to fat , ran through on demo and still the same 😡
hi i was wondering if any1 could help me iv got smart2go on my fone n it cant seem 2 find a gps signal
any ideas?
dj-relphy wrote:i didnt know i needed 1
i got told the n73 had gps built in
hasnt it?
no it has no gps built in you do need one...
can some one help me on the mem card is the one i posted any good?????
Hi there, just found this forum and loadsa good info.
Anyway, I found Navicore q good.
You will have google it as not allowed to paste URL yet.
Used it on me Nokia 6680 now transferred over to N73. So far so good, and i think you can get it for �80 including GPS reciever.
i got a 133x sd card and the map lagging is still there so dont waste your cash
Oow and now i have the bluetooth problem
nokia n73 ffssssssss cr*p..
You all need to get your firmware updated and get a ultra2 sd card, there much faster than the standard ones.
I have firmware v4.0711.2.0.1 on my N73 😃 (he he !! I have a mate that works at Nokia)
and TOMTOM v6.010 on a 2gb Sandisk Ultra2 MiniSD Card
Might I suggest that you disable your POI's, that might speed up your map lagging.
Oh, its the N95 that has built in GPS, not the N73
sc00byd00byd00 wrote:You all need to get your firmware updated and get a ultra2 sd card, there much faster than the standard ones.
nokia web site say new firmware is 3.0704.1.0.1
i will call at my nokia shop tomorrow its next to work...
my nokia repair shop say's there is no v4 ind i have allready got the latest firmware...
i all so returnd the sd card and got a sandisk ultre2 and to my surprise it did not work.. still have map lagging....
so nothing works...
Yeah I posted about this problem long ago and I never did find a solution. I bought a Ultra II card identical to what others were using yet the problem remained. I was using the same firmware and TT6 version as them. I'll probably look for alternative sat nav products.
Just to add to this, I have lag too, Ive tried 4 maps, New firmware, Reinstall TT. I cant belive there are so many people with this problem and there is no solution. I had TT5 on my 7610 and it was fault less. GRRRR
And just to top things off my phone started playing up and its going back to vodafone tomorrow
