I am trying to use a C lib into a C++ prgram for a Symbian project, but I have compilation errors: looks like my C++ compiler (gcc) cannot find the C function into my .lib whatever the way I try to link this lib.
As it looks like C++ programs does not really like C libraries especially when compiling for SymbianOS, I have directly included the C code into my C++ program, hoping it would solve the problem. But I have exactly the same problems: the functions are found in the .h files of the C library, but at the link etap the code in the .c files cannot be found.
So I would like to know if someone has already used C functions in a C++ program for Symbian, and if it is complicated. Has someone any solution please?
maxime wrote:Hi,I am trying to use a C lib into a C++ prgram for a Symbian project, but I have compilation errors: looks like my C++ compiler (gcc) cannot find the C function into my .lib whatever the way I try to link this lib.
all the C functions delcaration that you use in your C++ file must be defined in side (extern C)... for example if in your header file you should have
#ifdef __cplusplus
extern "C"
#endif
int add(int a, int b) ;
#ifdef __cplusplus
#endif
compile again all your c lib and now you can use add function in your cpp file
