X700 is very Slow
5 replies · 2,322 views · Started 13 March 2007
I'm just wondering if any1 else finds that the X700 is very slow?? I've had mine for bout 12months and i think it is getting slower?? I have a 256mb minisd in it?
Is there any way to speed it up?
Cheers, any help appreciated
Wirelessly posted (Nokia E70: Opera/8.01 (J2ME/MIDP; Opera Mini/3.0.6560/1630; en; U; ssr))
1. 3rd party Software to check&/monitor RAM.
2. Free up phone internal memory.
3. Not using too many heavy applications(RAM eaters) at the same time.
4. Update phone firmware to latest ,if available.
Thanks for that. Which program would you recommend to monitor?? Also i don't have any programs running, it's just slow to open contacts and slow to open messages.
Is there a way to store the sms inbox on the card and not the int-mem??
Cheers
Best TaskMan, Taskspy,or any other taskmanaging r application.
About sms,open the message section ,chck settings, chck under ths either text message settings or other settings ;there should be an option smwhr dr where you can change the location of storage for messages.
Still try option 1 and 2.
Applications like Best TaskMan (frm psiloc), Taskspy,or any other taskmanaging r application.
Thaks again....unfortunatly there is no setting to show the storage location. The best i can do is move to 1 of "my folders" but they are also on the int mem?? Grrr
