Tom Tom 6 and E61
4 replies · 3,152 views · Started 13 March 2007
Folks,
Do any of you happen to have a simple guide or tips to installing Tom tom 6 to an E61?
Their lack of information on this is astounding.
I get as far as getting all the part installed on the memory ard but it will not allow the sis to install.
Also which symbian option should I be using?
Thanks.
M
i have just purchased tom tom 6 with w.e. maps.
I have spoken to tom tom support and they are anything but helpful.
so at the moment I am as far as having the sis on my mini card but once i try to install I am getting.
unable to finish install from memory card. please install using app manager.
When i go to the app manager and go to install the nav s60 sis it will just do nothing.
I have reformatted my mini card from my desktop and copied the files for the app to it if that is of any use.
I had this problem too. Tom Tom acknowledges that the latest version of Tom Tom Home has a bug in it. they have the prior version listed on their web site for windows ME - remove the latest version of tom tom home, install the previous version, and make sure when it asks when tom tom home starts up not to install the new version - i did it AND ITS FINE NOW
