completely turn off the LED Flash
5 replies · 4,325 views · Started 15 March 2007
hello.
is there a way to completely turn off the LED Flash?
there is an OFF option but the LED still light up for a second, giving a blueish look on my photos. i want it to be completely off.
second question, my setting doesn't stick.... when I set the flash to be off, next time I start camera app it will set to auto again.
i have nokia N80ie
yup theres 3 ways
1 turn phone of forever 🙄
2 turn sleep mode off :icon13:
3 paint the led with a decent permant marker (i have done this ithasnt stopped it - but has nearly covered it all its just a dim flash now, if i had a torx 6 i would paint it more inside the case) :icon14:
bar those options then no
No I think he means the flash when you take pics. Don't think so me old mucker, you can turn the main flash off, but the led will still half light for photos.
no.. that micro flash appears whatever...
and always reverts to flash on with IE....
Might be an app that allows you to change that but I dont know of it.
This isn't ideal I grant you but, it's not too awkward a position to put your finger over the flash when taking a photo.
If you select "User" in the "Shooting Mode," you can adjust and save your settings. You still have to select it everytime you start the camera though.
KiN.
