Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/2.0.4012/1633; en; U; ssr))
Nokia lifeblog 1.7 not install on pc, showing "cannot start application-unable to initiate....
Directx problem"
Directx installed in my pc 9.0c, lifeblog 1.7 needs 9.0b as stated in its help. What causing the problem? Help me pl. Thanks.
Do you have a display adapter (video card) with only 16MB or less memory? If so, you can try lowering the resolution until the installer is happy (or upgrade your display adapter).
My display adapter is 64MB. I try by lowering the resolution,but no change of result.
