N70 Application manager problem
1 replies · 6,217 views · Started 16 March 2007
I changed the original 64MB memory card included in my N70 phone package with a RICOH 1GB memory card and then happily began to install applications on it. After about 20 applications when I tried to uninstall an unwanted app, I noticed that application manager won't open. I turned the phone off and on. I tried Appman 1.04, but I couldn't even get the list of installed applications. So I took out the memory card and everything became all right. Now I have formatted the memory card and want to begin installing applications, but I'm a bit reluctant about it. Will this happen again? Is there a limit for the number of apps one can install on N70?
Any comments are highly appreciated.
By the way the last application I installed was a game named Mazeness. And I tried a virus scan also with no results.
Noki70 wrote:I changed the original 64MB memory card included in my N70 phone package with a RICOH 1GB memory card and then happily began to install applications on it. After about 20 applications when I tried to uninstall an unwanted app, I noticed that application manager won't open. I turned the phone off and on. I tried Appman 1.04, but I couldn't even get the list of installed applications. So I took out the memory card and everything became all right. Now I have formatted the memory card and want to begin installing applications, but I'm a bit reluctant about it. Will this happen again? Is there a limit for the number of apps one can install on N70?
20 aplic? that's something. Have you made the firmware upgrade, i don;t know maybe the ney firm should work better, but anything is possible, but i think the best solution is to slow down on installing that many aplic, you should reconsider using only the ones you think you need.
