N73 me india's product code?
2 replies · 5,793 views · Started 16 March 2007
hello
id like to upgrade my N73 MUSIC EDITION Ver. 3.0638.0.0.30 -
30-10-2006 RM-133 to Ver. 3.0705.1.0.31 26.01.2007 rm-133
what is India's product code?
my big probelm is When I plug in my earphones (using the nokia AD-41 adaptor) I can hear some hissing noise even though nothing is running and playing.
When I start playing audio I can still hear this noise in the background and When a song starts or ends there is a loud tick noise...
thanks in advance
MY N73 ME current firmware Version:
3.0638.0.0.30
30-10-2006
RM-133
Nokia-N73(Z5.01)
To check your product code, take the back cover off, remove the battery, and it should be written on that white label.
I have the same phone,
3.0638.0.0.30
30-10-2006
RM-133
Nokia-N73(Z5.01)
My India Product code is 0543843. And I'm having a problem updating my software using Nokia Software Updater. I cant get an update EVERYTIME I run software updater it says that there is no NEW software, however I can reinstall the current one if i like? What is going on?? Anyone else having this problem??
