Hello all, this is my first post here, i purchased the Nokia N80 with the HS-12W bluetooth headset, everything was working fine, headset shows name, msgs, missed calls, time, etc. then i updated my phone with the nokia software updater and it updated my phone to the N80ie but now my headset doesnt detect names, time, msgs, etc. it still work but it doesnt show any information on the LCD, other than when someone calls me it says CALL thats about it, PLEASE HELP ME OUT HERE!! any help would be appreciated
Latest nokia n80 update broke my HS-12W headset
cmon guys, anyone ??? :con?
ok, so i guess no one knows!!! TOO BAD :frown:
It would make more sense and you might get some answers if you told the truth, if you used the nokia updater on an n80 IT WOULD NOT update the phone to the N80I, you must have used some third party flashing kit or something along those lines, so perhaps if you described exactly what software you used and what you did then people might be able to give you some answers.
mmmmmmmmmmmmm sorry i can't help u :redface:
peter7769 wrote:😡It would make more sense and you might get some answers if you told the truth, if you used the nokia updater on an n80 IT WOULD NOT update the phone to the N80I, you must have used some third party flashing kit or something along those lines, so perhaps if you described exactly what software you used and what you did then people might be able to give you some answers.
Nowday's it is possible to update from N80 to N80 IE whit the help of official Nokia Software Updater , no 3th party or iligal stuf requierd !!
So , he is telling the truth !! 🙄
all i did was downloaded the nokia updater software and updated my phone, i didnt use any third party software, according to nokia's website, when you download the latest version to your phone you get the n80IE version.
i tried reinstalling the updates so many times, re-pairing the headset, no luck, the headset works fine, i can make phone calls, but no ID names or time, msg, etc. shows on screen :icon13: 😡
Ooops, dont i look an idiot now:stupid:
you have a full apology from me, looks like i need to take a look at the new updater software!!, But it might be more trouble than its worth, my phone seems ok at the mo so as they say "if it aint broke dont try and fix it!!"
hope you get it sorted
Pete
peter7769 wrote:Ooops, dont i look an idiot now:stupid:Pete
Yup....:tongue:
Do you have the words headset and handset mixed up... Im struggling to find out whats not working?? The handset screen??
The HS-12W headset has a display/screen of its own:
http://europe.nokia.com/accessorieslink?s=HS-12W
In any case, the headset page (above) lists under "Compatibility" only 8800, 6288, 6280, 6233, 6151, 6131, 6085, 5300 and 5200. All S40 phones, and no S60 phones at all. If that info is to be trusted, it shouldn't even have worked with the N80 before the firmware update.
Oh aye.. so it does! Makes more sense now.... 😊
And N/A is very right on that compat list too.
i tried it with 2 phones (nokia n80) now and it works fine, mine and my friend's except mine when i did the update it doesnt display on screen anymore, but when i pair it with my friend's n80 it works fine (he didnt do update)
then it looks like you may have found the issue... have you called Nokia direct RE this?
