i know its a simple question but i cant find the answer.
What do i use to get the pics on my phone to the PC?
noyz25 wrote:i know its a simple question but i cant find the answer.
Connect the phone to your PC using the cable => select "Fast transfer mode" when asked by phone => Your phone's media-card should now appear as a drive in Windows Explorer => Browse to the location of your pic's (typically ...\picture.. on root) => Select your pic's and copy them to...
If you don't have your pic's on the media card you have to have PC Suite installed and select "Normal Transfer mode" upon connect. => your phone should now appear as "File Manager" in Windows Explorer => Select "Phone memory" and browse to your pic's.. select & copy...
