P800 - Sync Software working without probs?
2 replies · 3,358 views · Started 02 January 2003
is the P800 Sync Software working without problems?
I have made bad experiences in the past with Symbian devices and synchronizing...
Best wishes,
Martin
The sync-software works flawlessly on my main computer (Windows XP Pro, Office XP), using the included docking station and USB cable. (DCU-11)
I haven't tested the bluetooth connectivity to my laptop yet, but assume I'll test it during the first few days, after recovering from new years celebration..😊
- best regards, hallvard.
The sync software works "semi" okay but there are a few problems for me.
1. Appointments you "move" from the INBOX folder to another folder is not moved from the P800 inbox. Deleted msg. are deleted. Full sync is the only way to get the P800 Inbox "back in sync"
2. Full sync does not allways work (which makes the above problem extra anoying.)
3. The sync software takes far to many system resources (resident memory - and really a LOT of mem. when syncing.)
4. The bluetooth problems that TDK owners (WIDCOM BT stack) is the same that 7650 users have. (Look in the 7650 forum for info) That is because of the MR ROUTER. The MRRouter software some hours of work to clean up the code.
5. The USB connection is not very fast - is is still based on "serial" connection. Bluetooth (when it works) is just as fast. But moving MP3 and large files to the P800 is sooooo slow... Get a Memory Stick External Card Reader for it if you plan to move a lot of files around.
but all in all.. I love my P800 !!!! *G* and would not give it up for anything. My girlfriend got the 7650 - and she is happy...
Best
Kasper
