N73 - Backing up Contacts Help
2 replies · 3,650 views · Started 19 March 2007
Hey all,
Been having LOADS of problems with my N73 which I am sure you have all experienced (constant reboots, bluetooth connectivity failures, crashing etc)
So I spoke to my mate who works for Nokia, he works on the R&D Dept and upgraded my firmware to v4.0711.2.0.1 for me 😃
Hopefully all the bugs will be cured now
I backed up my contacts before posting it to him, but can't seem to get them all back now, I tried doing a restore from the memorycard of the backup that I did, but it kept crashing my phone, I had to keep doing a hard reset of the phone and set it up manually again !
I used to have some software on my N70 called "BackupContacts" which for a cheap bit of software, it was FANTASTIC, but it doesn't work on the N73, and unfortunately, Nokia PC Suite doesn't do what I need it to do either.
As you know of your reading this, some of the contact options you get on the symbian phones are contacts like; mobile(business), tel.(home), fax(business) etc etc.......
Unfortunately, Outlook only seems to back up the contacts that are just plain Home, Mobile, e-mail etc.....
Can anybody recommend any software that I could install that would backup these contacts to my MiniSD Card ?
Cheers,
Scott Lester :con? :con? :con?
