Hi
I have updated my firmware with the help of this program and now i have N80i. thanks a lot for the help and everything.:icon14:
now i have found one problem. when i try to enter my Call settings from Menu>>Settings>>Call the phone just exits and brings me back to the main menu. I have tried to reach there using other navigational ways but same thing happens. So now i can not access my call settings but all the other options are accessible and working fine. also other than this problem, the phone is working just fine ...😎
is there anything i can do to regain the access? :con?
regards
i had that and solved it, but i responded to the original post to keep things together here is the answer: http://www.allaboutsymbian.com/forum//forum/thread/56204/
hello guyz im a new to this forum and i have a question that may be asked many time i have a Nokia 6680 and it is a good phone but i think it is time to upgrade so im thinking about the N80 i like the wifi option very much as i need it alot , i will be getting the new internet edition is this firmware version is stable enough is it worth to upgrade to ?
thanks guyz waiting for ur response as it will help me taking the decision:redface:
elhamy201, Ive moved my answer to your duplicate post HERE!
