Nokia 3250 firmware/bluetooth issue
2 replies · 2,500 views · Started 20 March 2007
:dunno:
So I bought this phone not to long ago and beleive you me it does alot of S*&% I will most likely never use. What I do have an issue with is like say I'm in a resturant or whatever. My phone will ring like the text message ring and say "babygurl" has sent you a bluetooth message do you accept. I hit yes and then I get a message that says "program unable to be installed" or something like that. Anyone know if I need to update my firmware or something before I can use my bluetooth. Just so you know I bought this thing in Guam and there are ALOT of japanese tourist who come through and have phone that do **** I didn't know was possible. My phone came from japan an is only like a month or two old so I'm totally lost here....:nuts:
A lot of confusion. You should not accept software send to you by untrusted source. But if you want accept and install, then go to application manager, and change the status to install all software and not check the certificate on-line.
nj7 wrote:A lot of confusion. You should not accept software send to you by untrusted source. But if you want accept and install, then go to application manager, and change the status to install all software and not check the certificate on-line.
O ok,I was just curious to know if my phone could accept bluetooth messages...::shrugs::
