I've got N70 with CoPilot but want to switch to TomTom. Got the software and maps-it works fine BUT the GPS Receiver does not work. How can I pair the existing CoPilot receiver to work with TomTom??
Thanks,
f
Thanks,
f
N70 with Tomtom 5... It should came with GPS receiver from Tomtom, doesn�t it?
From the normal navigation screen select 56661 and configure to Other Bluetooth GPS
nj7 wrote:N70 with Tomtom 5... It should came with GPS receiver from Tomtom, doesn�t it?
no - got the software seperately, the phone came with CoPilot which is not great...
Thaks.
f
KenBruce wrote:From the normal navigation screen select 56661 and configure to Other Bluetooth GPS
Hi, it paired with the device but then there is NO VALID GPS SIGNAL message appearing😞 when switch to the normal screen GPS SIGNAL LOST xy MIN AGO appears...
any idea what may be wrong ?
thanks,
f
I get that message when the GPS receiver is paired but has not found enough satellites to work out the position. I wait for a minute or so OR move to a better location (more view of the sky). It is best not to be on the move while trying to get the first fix.
The GPS have a cold start and a hot start. The first time, cold start, can take several minutes before catch the signal.
