Hi,i just got an e50 with latest 6.41 version.i have some doubts about it.how much is free ram memory in it.My phone heats up while using as modem and charging.is it normal.it becomes hot to touch.is it a fault?
What file browser to use which gives full system access?
Some e50 doubts
No idea about free ram. Never yet received a memory full error message. My phone heats up too, even while talking for any length of time. The 6.41 firmware update reduced it somewhat. I think that this is due to some metal parts in the case that do not provide the same insulation as plastic. The same complaint is there with the 6300.
drpratik wrote:Hi,i just got an e50 with latest 6.41 version.i have some doubts about it.how much is free ram memory in it.My phone heats up while using as modem and charging.is it normal.it becomes hot to touch.is it a fault?
You can use FExplorer in order to see your e50 free ram memory. i have also e50 and FExplorer show 8545 kB ram memory (from which 8540 kB is free) and 68 MB phone memory.
Your heating problem could be due to a faulty battery. Phones normally get warm when charging, but it shouldn't be hot to the touch.
Try replacing the battery.
