Sync problems - best PIM?
1 replies · 3,667 views · Started 21 March 2007
I use my P990 with Outlook but I am not quite satisfied with the sync - PC-suite insists on syncing contacts that are not changed and sometimes add copies of those entries time after time. It seems to happen most frequently to contacts with photos. Very annoying..... 😡
Can anyone give me advice about this problem and is there a better PIM for the P990? Lotus Notes?
/Kjell
i had that problem when i first started using it. if you're using the SE pc suite, the duplicates that you are getting is due to your sync settings.
