How to disable N70 screensaver ??
6 replies · 11,063 views · Started 23 March 2007
Hi !!
How to disable the N70 screensaver that comes up after the specified idle time ??
It's very annoying !!
Does a firmware upgrade fix it ??
On screen settings you can change the time. But that is not dependent from firmware.
You can't disable the screen saver. Switch to one which you like or get a third party one.
hey raj,
it is very easy man... go to themes then edit them then shift to the screensave time & date.. its a matter of 5 seconds.. and u wont get that Nokia defolt screensaver again..
PM me if u want any gif screensaver for your nokia N70.. or send me any gif image and i will make screensaver of it for you.
and that also with light on for one minute like the orignal nokia N70 screensaver..
c ya
