Hi, i currently have a 512mb card in my N80 but have recently bought a 2Gb sd card for the phone. i was just wondering if there was a particular method of transferring the files from the old card to the new one. Bear in mind that TomTom, various games music and videos, texts and contacts are on the old card. can i simply use a card reader and copy the files??? Or do the applications have to be reinstalled on the new memory card??
thanks for the help, Kish
The applications need to be reinstalled.
hey thanks for the quik reply ... i thought the apps would need to be reinstalled .. it shouldnt take too long but im just lazy and was looking for an easy way out ... guess not
thanks .. kish
you can drag and drop the lot
save all files of the 512mb to a folder on the harddrive
format 2gb card in phone to get the basic files/folders
then drag and drop
works
Drag and drop with the hidden and system files also. On Explorer enable to show all files.
Hey thnx am tryin this out as i type, will let u know how i get on.
thanks again, kish
