I store all my messages (SMS and MMS) in miniSD. But I used to store them in phone memory, and then I switched.
When I look at my memory status by File Manager, it shows "Messages 27KB" even though I do not have any messages in my phone memory (or at least it looks like no message is in my phone memory) :con?
How can I clear this? I already tried normal reset (*#7780#) and it did not help.
I appreciate any suggestion and/or idea. Thank you!
That could be only the registry of messages, not real messages on phone memory.
Thanks, nj7.
Can you please elaborate about "the registry of messages" a little more?
Excuse my ignorance ... thanks!
Messages are a system folder. Even after all delete, the phone remains with that functionality. So some space must be allocated on the OS for that.
think it will be the templates you cant delete mate:icon14:
Thanks you all.
Well, I'm not going to sweat about it then 😉
Try the following steps -
- Switch back the Message save setting to Phone Memory.
- Close the Application
- Reopen and change it back to Memory card.
- Switch off and remove the miniSD
- Switch ON
- Clear all your existing messages in your inbox (This would be your phone memory content)
- Put back your miniSD
and will be all set. !!!
- Cheers,
Ravi.
