PsiLoc have made available a screen capture program for the SE P800. This program enables you to take screenshots with a keypress and allows you to save in various qualities and formats.
Author Notes:
The SE P800 do not have screen capture utility. With Screen Capture you can capture screen contents anytime using a defined key.
Pictures are saved in a folder accessible via the Pictures application. You can select one of three formats: JPG high quality, JPG low quality or MBM. Screen Capture works in the background and has no influence on any other running applications.
