[FONT="Times New Roman"]Hey folks...
Plzzz tell me how do i use my N72 's cam as web cam on yahoo messngr....
only via.... DATA CABLE...... which software 2 download ???[/FONT]😊
N72 's cam as web cam via DATA CABLE...!!!
Mobiola web cam from software section of this site.
Dude i tried that software.... But its showing serial port is locked by the system or application.... Do any1 know how 2 unlock it ????????
N can i use mobiola via datacable ???????
Is the only one I know for S60v2. Read the user manual!
Uncheck the cable in connection manager from PC Suite.
Hey dude Thxxxxxxxx a lottttttt my tis probzzzz is solvd... but yet i m not able 2 c any usb connection in that software ...... on bluetooth option is provided...
can u help me out in tis plzzzzzzzz.......
Hey dude mine tis probzzzz is also sovled...... Thxxx a lot dude..!!!!!
can any1 plzzzz giv me the .... keycode.....
Mobiola Web Camera [SIZE="2"]USB[/SIZE]
IMEI :- 359400004894274
Sr num : - ???????????? needed......
Serial number will be provided to you by Warelex (Mobiola webcam's developer) after you buy it.
Can i get it from somewhr else ... widout buying it ???????
From developer, if he wants to give it to you for free.
