apps go missing - on sd
1 replies · 1,944 views · Started 26 March 2007
Got new phone, had a play with WorldMate and Weather apps, moved their icons to useful places. Then got my 1Gb MiniSD, and removed the 64Mb one and apps vanish. Swap back and they re-appear. How do I get them off the old SD and onto the phone or new SD ? Thx Ian
ianadd wrote:How do I get them off the old SD and onto the phone or new SD ?
If you haven't already installed any apps on the new SD, then simply copy all files from old SD onto new SD (using card reader or similar). This will work if the new SD is relatively fresh and doesn't have any app data such as email etc (otherwise you risk losing said data).
