Media Studio
0 replies · 1,865 views · Started 27 March 2007
Has anyone else tried Media Studio on their E61 or E62??? It is very easy to convert and very fast. Just on or two clicks and you are on the way. The problem that I have is it is suppose to work on RealPlayer. The sound is great and the picture is very clear---but it doesn't move. I just stays on the same picture and doesn't move---like a photo. I am using the video clips facility which comes on in MyFiles. If the movie would actually play I would by it as I am using the trial version.
It is much easier and quicker than SmartMovie which I have and it works fine. The biggest problem with it is, and its probably me, is that when I go to the D-drive on my Laptop to convert the DVD to the file for my phone using SmartMovie on the line that says "Look in" it gives the title of the DVD and then on the line that says "file name" it
is blank and I need to put something in there to identify the DVD and on the "files of type" it says video or all files. I have don't it before but its been quite awhile and I forgot what to put in those spaces. Can any one refresh me please. I can convert files just fine that are downloaded form on line to my laptop, its just the ones on DVD that I forgot how to do.
Thanks,
Bob
