Did anyone see the slashdot story about this java x86 emulator?
http://www.physics.ox.ac.uk/jpc/
looks like it works on the Commie!
http://www.physics.ox.ac.uk/jpc/Nokia.html
Yes I heard about it on the My Symbian forum and tried the links at the original website unsuccessfully--my 9300 said that it could not download the necessary files after running the .jad downloaded to my mobile.
A poster from Poland had a version which uses "SCORCHED" which did successfully install, but when I run it all I get is a white screen with the green "G" in the upper-right-hand corner. The menu button reveals only three choices "INPUT, EXIT and EXIT". Upon selecting INPUT, a dialog box opens. Nothing that I typed in this box appears to do anything.
Have you gotten this working on the 9300/9500? If so, how?
