New: ObjectData for Series 60
1 replies · 2,336 views · Started 02 January 2003
Corisoft has released ObjectData, an object database. It has been developed specifically for the Nokia 7650 smart phone in order to easily create databases that can be viewed on the device.
Features (from Corisoft):
- Create and Delete databases directly from your Nokia 7650
- Save and Save as databases directly from your Nokia 7650
- Add, edit, duplicate and delete records directly from your Nokia 7650
- Send databases through infrared, bluetooth or email to other Nokia 7650 or PC.
- Import Nokia 7650 databases into ObjectData for windows.
- Database encryption with password
- Send your datas to the notepad then send datas through SMS, MMS, BlueTooth, Infrared.
For more information go to Corisoft. You can download a trial on this site or buy the software for �18.
