What next after 6630 - upgrade to what??
7 replies · 3,722 views · Started 28 March 2007
Good day guys, my contract has just ended and i have had my 6630 for nearly 2 years and have been pretty happy with it.
My question to you guys is what next, my other half has an N80, the main problem i see with it is it battery life or should i say lack of.
Any one moved on from the 6630 and found a better NOKIA phone??
let me know your thoughts / ideas.
Cheers
Dai O
Well... in Nokia terms, as I'm sure you already know, the next upgrade from the 6630 was the 6680 ( which is my current phone ). This was then replaced by the N70 and that has been superceded by the N73.
So, you could follow that route, or just jump straight to the N73. Or wait for the N95 ( looks very nice IMHO )? My contract is up on August, so deciding whether to keep my trusty 6680 or move onto the N series phones.
[SIZE="4"]Hi . . . . .
I suggest 3 modesl, 6233, 6300 & N95. you can check the specs of these at www . gsmarena . com ( I cant yet post a link here so just remove the spaces and use the link) and compare and decide which one suits you. I have 6630 and my next stop is 6233 or 6300 which ever I can get my hands on. I woudl love to go for N95 but thats out of my range. All these 3 models are different fron each other. If you like slim phones then definitely go for 6300, 6233 is considered as music phone and if you want a hi-fi phone, then N95 is for you. As you said that your better hald as N80 so I guess you would like to go one better than her 😉 . In that case choose N95. It has everything that you would want in a high-tech phone. Memory, battery timings, camera, etc. If you want to get a phone better than N80 than the obvious choice is N95. If thats not your concern then choose between 6300 and N95. Let me know if you need more help. Whenever I change my mobile I spend sometime doing the research and comapring and weighing the options. So I would be glad to be of any help.
[/SIZE]
Dai O wrote:Good day guys, my contract has just ended and i have had my 6630 for nearly 2 years and have been pretty happy with it.
Cheers
Dai O
Go to www.nokia.com and see! The possibilities are so many🙄 Check what you want best, battery, camera, light, small, etc...
Yes, you will need two things to get the 6630 to work as sat nav phone:
1 - Software installed into your phone's memory card eg TomTom
2 - A GPS receiver. Can be bought for around �40 online / eBay.
thnk you i ll buy it nottmbantam ahahahahah do you know that has made me speaking with my self this fone cause i thought that i can do that with out reciever gps now i understand thnk u but all of them your gilfriends it pity but dont be wory thy are lot of them in the world i see that men that are litel instead ahahahaha
schade_1_2 wrote:... but all of them your gilfriends it pity but dont be wory thy are lot of them in the world i see that men that are litel instead ahahahaha
didn't quite understand this bit!
You're welcome, hope it all works out.
