I have a question... Did anyone notice, that when you call somebody, and if that somebody doesn't answer, and you close the slider down, it doesn't actually cancel/end the call. You have to push the RED/NO button to end it.
BUT... If that 'somebody' answers and you close the slider down, it works as it should - it ends the call.
I hope you understand my problem :con? And hope that there is a solution.. Thanks, Jan
AlfaGT wrote:I have a question... Did anyone notice, that when you call somebody, and if that somebody doesn't answer, and you close the slider down, it doesn't actually cancel/end the call. You have to push the READ/NO button to end it. BUT... If that 'somebody' answers and you close the slider down, it works as it should - it ends the call.
The N80 can be tempramental doing exactly as you say.
I tend to find, slide up then down again solves the issue 😊
If they dont answer and no answer machine is on it will end the call itself
Cheers
hm, but is there no way, that when i close the slider down it just simply ends the call (when there is no answer)? I have to push the Red button and it's slowly going on my nerves, because sometimes i forget to push it and it still keeps on ringing. 😡
-> you really have to Close it, open it and close it again to take affect. Thanks
P:icon4: :icon4: $es me off to you arent alone on this one
**:icon4: power to the people:icon14: **
just tried this on my home phone.......works on my phone !!
Jeah.. what works?? Your home phone or the slider on Nokia N80 😮
