N80 Txt Problem
3 replies · 1,844 views · Started 31 March 2007
I am having a problem with my N80 where it will not tell me when i recieve a new txt,i have to manually go into the message centre to find out if i have one or not
It wont vibrate or play a sound,now matter what profile it is in
Ive tried a light reset but that is all,does anyone know what could be wrong??
Phoning my mobile is a different matter,it will happily play and vibrate away
Im very annoyed with it!!! 😡
Cheers - Uni
are you using the same 'sound' for each profile when you recieve a text...
can you change it??
does that work any better??
kontraband wrote:are you using the same 'sound' for each profile when you recieve a text...
can you change it??
No not using the same sound for every profile and even when i do change it still no joy!!
