i recentily reset my phone and i used to slide to answer and end calls this does not work not (since i reset) i was wondering if any one could help me find this setting it is a nokia n80 os:s60
ending and answering calls
depending on when you slide closed the phone depends on whether the call ends on some handsets it seems... If I dial my number and close the handset after a few seconds the phone will continue to ring...
If however your closing you call after longer than that and its not closing the line then there may be a problem with the sensor that knows if its closed or not...
are you opening/closed lights working as normal?
