3230 Installed Games
4 replies · 2,156 views · Started 01 April 2007
:icon2: :icon2: Hi its me again mick78,
I was wondering if there was a way to delete the already installed
games on my 3230. The games are Agent V, Rally Pro Contest and Warrior.
Does anyone know how to delete these already installed games !!
Thanks 😊 😉
With "Application Manager". If they're installed in ROM (Read-Only Memory), then there is no way.
You cannot delete them. All you can do is to put them into a folder in which you keep all the "trash".
Is there a way to put them into some folder or program on the phone so that I am not using the phone memory? Or can I install them onto the memory card somehow?
When you start installing a program, you're asked where you would like to install it: either on the phone or on MMC.
