hi guys.. i duno if this hab been ask b4... i hab a N73 , and jus update the software from 2.0628.0.0.1 to 3.0704.1.0.1 but all my jar files and games cant be installed back into my phone. wat happen? thanks
cant install jar files into n73
Instead of asking us, how about if you tell us what happens (we don't know as we can't see your phone through this discussion forum)?
How do you try to install them? What error message do you get?
Note also the setting: menu > Tools > App.mgr > Options > Settings > Software installation > All.
opps... sorry! ok i used to hab jar games in my n73 (old version) den i update my firmware using the cable to the latest firmware. But all the jar files in my phone only has the icon, when i click it is not workin anymore, is jus a icon.
Den i tried to install it using both my memory card n cable way, but my phone only shows "installing........." i waited for quite sometime, is still "installing............" never prompt any error msg.. is only the jar files, the sis files still can be install.. i tired to uninstall the jar files and reinstall again also the same... the
installing............" bar still there..
anyway i hab already set the software installation to ALL already.
Hope u can understand wat im trying to say.. thanks!
