Just a couple of questions
1 replies · 3,820 views · Started 02 April 2007
Hey, I have a N80 and am looking to get an N95 asap but just have a couple of q's.
1. What type of memory card does i take?
2. Does it run S60 3rd or is it using a new OS. (in other words will the software i currently have on my N80 work on the N95?
3. What is the battery life like on it?
4. Is it really all its cracked up to be and worth the hasstle of a premature upgrade?
1. microSD
2. Software will work, but it is running the next revision (i.e. S60 3rd Edition Feature Pack 1).
3. Its OK, but great. Depends on usage. Much like the N80 I feel.
4. Only you can decide that - depends what you want to do with it, but I think its a significant upgrade from the N80.
