Bluetooth car kit volume
4 replies · 2,881 views · Started 02 April 2007
Has anyone tried their N95 with a Bluetooth car kit yet?
Mine is incredibly quiet when used on the same car kit that was fine with my N73.
Mine is fine with a Vauxhall Carkit - however, it won't transfer the contacts and call details to the carkit...
stuclark wrote:Has anyone tried their N95 with a Bluetooth car kit yet?
mine is the same but it was ok with my n70
Seems obvious but have you tried turning the volume up on the handset when its connected (the same way you control the volume when on a call)?
I've had a 6680, N80 and now an N95 - all are perfect volume on my bluetooth handsfree
Neil
Well, yes - of course all phone volumes turned up to max (I also found you have to turn music player to max)
It seems that this could be a Bluetooth implementation / hardware fault on the N95 as some people are seeing the problem and some aren't.
My N95 is away for replacement at the moment anyway, so when I get my new one back I'll let you know if that is any different.
Maybe the new firmware which seems to have just been released will have a BT fix in it.
(N70, N73 ans SE W950i all work fine on my car kit, so it's not that)
