3230 Speakers and Equilazer
4 replies · 2,234 views · Started 03 April 2007
Hi me again.
I was wondering if there was a way to turn up the volume on the 3230. Because mine is still very low even when I change the volume to highest. My mates said that there should be a Equalizer on my phone but I can't find it.
Can anyone help me with this problem?
:icon2: Thanks :icon14: Micky
Check only if you have the last firmware version, and of course, if is not the case, do the upgrade. You can�t do a lot more for that!
There is no inbuilt equalizer in 3230 and you cannot do anything to boost the volume, unless if you convert your tonnes to ''yell" louder.
Yeah!!! These nokians might be tired while finishing its speaker and sound system, thats why all these beep bugs and low volume are the major problems in n3230😡
