S60 spec table update
3 replies · 2,110 views · Started 03 April 2007
Just a note that I've done a big update to my 3-Lib 'S60 History' page, detailing the specs and features of every S60 smartphone since the 7650. Comments welcome!
That's great!
However, I think you ought to add notes next to the processor speeds if the smartphone contains a second processor. The clock speed alone is a bit deceptive on models that have a second processor.
As Jukka from S60 noted, the second processor handles telephony tasks leaving the main processor free to do computing. If a smartphone doesn't have a second processor, it has to split its computing time between the computer and the telephone, so its nominal clock speed counts for less.
Nice and up to date! I would also like to see weight and it would be cool if they were in a dropdown or something so that you could compare 2 phones side to side.
I might convert this table in to excel so I can compare more easily. If I do it, i'll send you the .xls
Samsung i520 CPU is OMAP 2430 according to Mobile Review.
